Just a had a little test run and I’m really impressed on the speed improvement, the V3 is coming with, great job on that.
There seems to be same issue what was there with V2 also thought, you cannot select hifiberry Digi+ Pro from i2c dropdown or you get no sound. Have to select snd_hifiberry_digi(?) From the drop down menu instead after deactivating i2c dac.
I’ll provide the logs later since the test was done while driving to work.
An issue I have is when I play albums from my NAS disk, I am perfectly able to start playing an album by clicking the album title.
But I am not able to play a song by selecting the song in the list of songs in the album.
Volumio is scanning my NAS (from the Fritzbox) But Artists, Albums and so on stay on zero.
Under Music Library I see the NAS and the folders, but no music files.
No Artists, no Albums and no Genres.
select snd_hifiberry instead of the headphones/HDMI and save.
It should work then, at least on PI4 this prodesure is needed to get it working.
For the crackling make sure you are not feeding too high resolution audio to the hifiberry or it will do that, i think the ic in it tops at 24/96 or so.
In settings>playback options>general playback option>playback mode set this to single (default is continuous) otherwise itll add all the tracks from the album to the queue regardless of whether you select an indiviual track or not
seems not to be specific to FusionDSP - sorry.
After starting another internet radio station and switching back to the one before it is working.
seems to have more to do with the behavior that i described before, that internet radio stations sometimes have to be clicked twice before sound is played (nothing to do with FusionDSP and Multiroom) - and with the fact that doing too much on the receivers UI it hangs up. (only setting the Volume never caused an issue).
I think some functions on the receiver should be “greyed out” while it is in “receiver mode” or do an automatic ungroup as soon as another source is selected on the “receiver”.
Im having a test with the fusion dsp, seems a very nice addon, but…when using the parametric eq.
Im using peaking Hz,Db,Q, enter the values separated by comma works fine, its when I use the highshelf Hz,Db,Q or lowshelf Hz,Db,Q it complains that “missing bandwidth in db/Octave”, values were entered in the same way as using the peaking Hz,Db,Q
If this is the wrong place to be discussing the dsp i apologise.
Pi 4 to SMSL 8Su USB DAC. Thanks for putting new release out in beta…
Here is what I have noticed:
Seems more stable
Takes longer to boot up and the screen plug in takes much longer to boot up,
Seems to have fixed the problem where Qobuz skips to next song after it has been paused
The DSD setting seems to be backwards. When you turn on DSD Direct the DAC converts to PCM but when you use DSD over PCM then it displays DSD accordingly. This seems to be backwards. Still works but in reverse.
Hello Volumio heroes
The new Volumio 3.x is really much better than the 2.x version. The stability is much better, even after several days the system is still stable and fast. That is a point that I very much appreciate.
From my point of view, version 3.x no longer needs the little word “beta”.
Quite simply, I practically only use Internet radio, Qobuz and sometimes my Flacs on my NAS.
RPI2, RPI3, Allo BOSS, HifiBerry DAC Pro + XLR and sometimes even RPI (1) with HifiBerry DAC.
So far I have hardly used any other plug-ins, but I think it’s fantastic that they exist, the new FusionDSP is an asset to the plug-in collection.
Thank you very much to everyone who drives Volumio!
I have an Allo USBridge Signature. I’ve experimented with this and another OS that seems to be going in a similar direction. The other OS only supports Tidal via UPnP(I got Volumio specifically for Tidal Connect), but offers “64 bit driver support for the Allo USBridge Sig”. Is 64 bit for USBridge something you’ll be doing?
