Same issue than Volumio 2. I can play a song and skip to another one by myself without any issues, each song is played correctly (Qobuz). But by playing the queue, It is not working anymore. To explain, between two songs (the first and the second in the html log exactly), I get alsa output failed and hw_params shows “closed”. but it seems between the second and the third there is no issue. I clearly don’t understand why sometimes next song is played and sometimes not, why output communication is lost.
I just received from ATOLL provider this DAC is alsa compatible and works from 16bits to 24 bits properly.
Just installed the 3.114 on the PI 4 and everything went smoothly. One thing I noticed is that with this RC, I’m unable to play any music, as Spotify seems to be missing in action.
I did find the Spotify Connect plugin available, but when I listen to music, I want to get away from all smart devices, so Spotify Connect is unfortunately not an option.
The way I listen to music, is with a keyboard on my lap and volumio’s big album cover art displayed on my TV.
I tried to find a roadmap, but the name release candidate indicates that Volumio might launch without Spotify integration. Is this the case?
Having said that, the install process went smoothly. Can’t wait to try a version with streaming integration (and the new DSP features)
The re-introduction of plugins (Spotify, in this case) is an ongoing process for Volumio 3 release candidates. Please bear with the Volumio Team as plugins are checked, to ensure a smooth transition.
Thank you for the info! Didn’t mean to sound like I’m rushing things. I can happily use 2.x version until then. Version 3 does sound like a game changer!
This is what happens if I navigate to this album from the Genre menu. If I navigate to this album from the Album menu, the album opens up and can be played normally:
Could you please repeat the log, it needs to be from a fresh reboot immediately after reproducing the problem. The previous one is way too long for us to analyse.
When I have the FusionDsp active I have to click two or three times on the radio channel in the queue or the play botton to make it start to play, local/nas files works fine.
If I deactivate the plugin I only need a single click to make a radio channel play
Title: Problem with Qobuz and purchased tracks, when DSP plugin is enabled
I don’t own a Qobuz subscription, but I have bought albums and tracks from Qobuz. To my surprise, I can access and play these purchases in version 3.114, which was unexpected and great!
There is a small problem though: Each track I play from the single tracks I have purchased, stop playing audio abruptly 3-5 seconds before the song ends. Also next song from the queue doesn’t start playing when the previous track ends.
So what happened is that audio of Levitating stopped 3-5 seconds to early. Next song should have been Another One Bites The Dust, but it didn’t start playing.
This happens when I have the DSP plugin enabled. If I disable the DSP plugin, the next song in the queue starts playing as expected.
Does anyone have this issue (in all versions) where tapping the play/pause button sometimes doesn’t register (on tablet touchscreen, in web interface)… like you have to tap it a couple of times for it to play or pause?
